Easy fix for a bent rim
I just fixed my bent rim I was going to get an ITP replacement but I have it back to normal with no wobble. All you do is get a piece of chalk or a white colored pencil and jack the front end of the bike off the ground. Spin the tire around and hold the chalk so its hitting the highest part of the wobble out.
When the tire stops you'll see a white mark on one end of the tire. Take the tire off and on the opposite side the white mark take a washer or 2 and put it behind the wheel stud to bring the tire out and get rid of the wobble.
May take some fine tuning but I went from a barely drivable front tire to one thats as good as new without dishing out 100 bucks. Hope this saves you some cash.
on my predator i had, i bent a .190 rim like the 1st week i had it. i used a 10 pound sledge to beat it back cuz a 2 pound sledge wouldnt touch it. i cant imagine the force it took to bend it. i dont even know how it happened. but yea, BFH is the way to go. i mean REALLY BIG FUCKIN HAMMER. :D
I get little dents in mine all the time, usually doesnt get into the bead area to bad, .190's are a pain to beat back but a BFH always works, It also helps if you have a Nac's Beadbreaker to pop the tire off if you gotta do some major work to them, just makes it a lot easier. The beadbreaker was the best item I've ever bought. It's gotten me out of some tough situations.
This freaking rim that I beat on at LS was bad. We were busting some trails, up and down through the hilly shit. These shitheads were sitting in the bottom of a gulley and we had a big brake check, and this other guy comes bailing over the top of the hill behind me and slams into my rear tire, and it pushed the bead of my rim all the way out. It was like someone took a huge pair of pliers, grabbed the inside bead of the rim and just peeled it back, I could get my hand in between the rim and the tire. Blue's BFH helped beat on that thing. It took some serious coersion, but you should see it, I felt like an artist working the aluminum back into shape, I'll get a pic of the finished product.
I'll definitely check into Nac's beadbreaker.
Edited by sredish
