What a Deal?
hey a 2003 'shee with Procircuit pipes, Boyseen reeds/Spacer/Boost bottle/ UNI and bearclaw tires for 6000$ (canadian) Is a deal eh? the left front shock was a little bent, but it was pushed back, other than that its mint.
my question/beef is should i modify/upgrade the cooling system and the clutch to handle the power of these mods, or can I just skip right to buying a front end suspension kit from alba (shocks/lines/arms)
{f anyone wants a 1988 Banshee with 13-44 gearing, 2 sets of rear tires, float gaurds, new cables/ new electrical shit (gotta fix that first) and a fresh rebuild (cases split, 40 thou overbore with wiseco pro-lites, and an extra plate in the clutch) for 2200$ canadian gimme a shout at mavguy@hotmail.com}
I ride mostly trails/mx/sand/ditch.
Guys, lets stick to the subjects at hand and not hijack the threads with something completely off topic.
For that price, yes it's a deal as long as there is no frame damage. Why is the shock bent?? What else bent? The shocks are tough suckers so i'd be amazed if nothing else was bent. As far as the cooling system, leave it alone. We're pushing a bit over 100hp through a completely stock system without issues (yes, even the head is stock). The clutch on the other hand sucks from the factory so it should be replaced with a HD clutch when the stocker frys. The HD kit is just gold springs, fibers, and steels. Bolt in and go. Keep the trans oil fresh and even the stocker will last a long time.
