LanceG60 Posted June 21, 2004 Report Share Posted June 21, 2004 The nut is off one side, and I can spin the side with the head of the bolt on it, but it won't come out. I smashed it with a hammer and it wouldn't come out so now I need a new bolt...but what is going on. I at least need to get this one out. Quote Link to comment Share on other sites More sharing options...
Brian G Posted June 21, 2004 Report Share Posted June 21, 2004 You are not alone on this one!!! this is a trademark for the banshee!!! I had to cut mine out with a torch!!! and ruined the swingarm!! but it really just takes some mustard!!! get a propane torch and heat the shit out of both ends of the bolt get some type of punch that will go in the hole at the threaded end of the bolt and get the biggest hammer you can find, personally I would use a mull or a massive sledge hammer and eat a bowl of wheaties before!!! then just start pounding the shit out of it. dont stop, it will come loose it might take 2 days but it will come out!!! and just go buy the new bolt right now because the old one is toast!! Quote Link to comment Share on other sites More sharing options...
DirtRider Posted June 21, 2004 Report Share Posted June 21, 2004 yeah while your buying the new bolt buy some new bearings too. but wait untill you get the old one out first. might as well put in the zirk fitting while its off. take a 5/8 rod about a foot long and put that in there and have a brave soul hold it there while you hit it with a sledge. should come right out if your doing it right. no matter how bent it is, its hollow. though im not talking from experience so thats just my .02 Quote Link to comment Share on other sites More sharing options...
LanceG60 Posted June 22, 2004 Author Report Share Posted June 22, 2004 Ya I tried everything I could at home...tomorrow it comes to work with me and is getting torched. I'll heat it first but I think I'm just gonna cut the swingarm so I have to get a new one heh. Quote Link to comment Share on other sites More sharing options...
racer Posted June 22, 2004 Report Share Posted June 22, 2004 get an air chisel with the right attachment, that pound the shit out of anything. then just go at it for a while Quote Link to comment Share on other sites More sharing options...
LegendSS28 Posted June 22, 2004 Report Share Posted June 22, 2004 Wouldnt heating it with a torch make it expand, thus making it harder to get out? Quote Link to comment Share on other sites More sharing options...
Nighty Posted June 22, 2004 Report Share Posted June 22, 2004 just wondering.. is everything else lose? suspension, linkage, rear axle.. the whole shizlock? Quote Link to comment Share on other sites More sharing options...
Holyman Posted June 22, 2004 Report Share Posted June 22, 2004 Just so you know what's going on here is the assembly order starting from the outside... The swingarm, bearings, sleeve, dustcaps on the ends of the swingarm, bolt goes thru frame, dustcaps, sleeve and nut goes on the other side. The problem is the bolt is rusted to the inside of the sleeve. Heating the bolt will probably have no real effect since it is #1 rusted and #2 10inches long and would have to be heated the length of the bolt. The best thing to do is tip the quad to the side so you can get good straight on hits and hit it with a heavy hammer. The heaviest hammer you can get without hitting the frame. Once you get some movement, drive it back the other way. This will break the rust loose. If you havene't already ruined the threads on the bolt, get a spare nut and pound on that instead of directly on the bolt. The problem is if you mash over the end of the bolt, it won't go thru the hole in the frame but if you hammer on the nut, once you get it loose enough, you can take off the nut and drive the bolt out the rest of the way using a punch or piece of metal rod. Once you have it all out, I suggest installing a grease fitting in your swingarm which should prevent you ever having to mess with it again. Do a search for the pics I had posted. If you can't find 'em, I'll repost them here. Quote Link to comment Share on other sites More sharing options...
Banshee169 Posted June 22, 2004 Report Share Posted June 22, 2004 I am in total argeement with Holyman. I had the same problem with my 87 and thats how I took care of the bastard. The grease zerk is a great idea too. Easy to do and very beneficial. Quote Link to comment Share on other sites More sharing options...
ledofthezep Posted June 22, 2004 Report Share Posted June 22, 2004 I've been fortunate enough to just have to slide mine out each time. Just keep it well lubed would be my best suggestion, you may have to get a punch & pound that bitch out, and maybe get a new bolt for it. You think a banshee's bad, try a 400ex swingarm pivot bolt sometime. Quote Link to comment Share on other sites More sharing options...
LanceG60 Posted June 22, 2004 Author Report Share Posted June 22, 2004 ya...I was hitting it with a sledge on a punch and it just drove the punch into the hole in the bolt. So then I took the sledge straight to the bolt and it still never moved. Thats why I'm resorting to the torches. Quote Link to comment Share on other sites More sharing options...
Brian G Posted June 23, 2004 Report Share Posted June 23, 2004 Yeah, just take the shock off and chop that sucker in half!!!! Quote Link to comment Share on other sites More sharing options...
Josh A. Posted June 23, 2004 Report Share Posted June 23, 2004 lol, if the shock is off have some one lift the arm up, and put a long screw driver in the hole to were its touchin the bolt and it will come right out, if the shock isnt off have someone there to help you just wibble and wobble it Quote Link to comment Share on other sites More sharing options...
powerman350 Posted June 23, 2004 Report Share Posted June 23, 2004 I had this problem and I soaked it with wd 40 and had my wife turn the bolt head with a ratchet while I smacked with a hammer (with a nut on the the threads) and it finnaly broke free. then I soaked it more with wd and smacked it back and forth and turned it with a ratchet until it came out. Its kinda looked liked a circus act or a monkey f&%@ing a football but it worked. Quote Link to comment Share on other sites More sharing options...
Noob Banshee Posted July 15, 2004 Report Share Posted July 15, 2004 HOLLY CRAP IM NOT ALONE!!!! I have that happening right now!!! on my 87 where the shock bolt on the frame meet!!!! i cant get the SOB to come off....so i was going to use a dye grinder to cut the head off!!!!! Quote Link to comment Share on other sites More sharing options...
