boonman Posted June 23, 2004 Report Share Posted June 23, 2004 Hopefully the floats won't stick after you clean the carbs?? That would suck!!!! I hate clanin carbs, I hate jetting. I flat out hate messin with my bike. I like to ride when I can. I have ben doing that for a while.. lol Like Benny said, if you don't have fuel on the plugs, there is a problem. I would think that with the amount of time you have been kicking it over, you should have an assload of fuel in there..... unless it's not getting any.... being the age of the machine and what not, the jets may be gummed up.... Quote Link to comment Share on other sites More sharing options...
cdcoxwell Posted June 23, 2004 Author Report Share Posted June 23, 2004 OK, today's the day for PROJECT CARB CLEANING (echo,echo,echo). I get off at 3:00 so cross your fingers on getting her cranked Thx Cary Quote Link to comment Share on other sites More sharing options...
boonman Posted June 23, 2004 Report Share Posted June 23, 2004 Good luck brother CD!!!! I'll keep my fingers crossed. I have to wrench on the bike a little myself. (going to Silver Lake dunes tomorrow..) Maybe it will be a good day for wrenchin bikes..... Quote Link to comment Share on other sites More sharing options...
MULLET~BOY Posted June 23, 2004 Report Share Posted June 23, 2004 compresion test arnt acurate usaly some read high and some read low long as both your cylinders are at the same psi your fine deffently sounds like you got some crap in your carbs have you tried starting it and riding around to see if it clears up Quote Link to comment Share on other sites More sharing options...
cdcoxwell Posted June 24, 2004 Author Report Share Posted June 24, 2004 Mullet, shee will not crank at all Quote Link to comment Share on other sites More sharing options...
boonman Posted June 24, 2004 Report Share Posted June 24, 2004 Did we get the carbs cleaned yet? Quote Link to comment Share on other sites More sharing options...
cdcoxwell Posted June 24, 2004 Author Report Share Posted June 24, 2004 Got the carbs cleaned. Still would not crank . Got-a-buddy to pull me and after about 50yds w/the throttle floored shee spit and sputtered until shee cranked. . Shee will not idle at all, as soon as you quit giving her the gas shee goes dead. Shee will kickstart now. Also, the shee is bare, so there's no airfilter on her at this time. I don't want to put back together untill I know what is going on. I should have gotten someone to pull me off before I cleaned the carbs, that may have help w/some answers. I was told that shee would still crank while shee's hot if there is engine problems. He said wait a while and when shee cools down, then try to crank her and go from there. So, tell me what you guys think. What's my next move ??? Cary Quote Link to comment Share on other sites More sharing options...
PUSH THE THROTTLE Posted June 24, 2004 Report Share Posted June 24, 2004 Sounds like it has to be your jetting. Adjust your air screws and check and re-check your pilot jet. Also you should put your filter back on because you will be running it with an airfilter any way so if you get it running now with it on you won't have to adjust jetting when your done. Plus it's just bad for the Shee to run without an air filter that could very well be why your carb is jacked up. Quote Link to comment Share on other sites More sharing options...
cdcoxwell Posted June 24, 2004 Author Report Share Posted June 24, 2004 Thx Push, doing that right now. Quote Link to comment Share on other sites More sharing options...
cdcoxwell Posted June 25, 2004 Author Report Share Posted June 25, 2004 Is there anybody out there. Just knod if you can hear me. Is there anyone at home??? Where are you people . For those of you that don't know, those are lyrics from FLOYD. Cary Quote Link to comment Share on other sites More sharing options...
MULLET~BOY Posted June 25, 2004 Report Share Posted June 25, 2004 (edited) thats a good song !! try tieing a tow strap to the front of your bumper and have some one pull start you i'm sure you have already tried new plugs ifnot try there probably fucked from sitting there kicking and not starting Edited June 25, 2004 by MULLET~BOY Quote Link to comment Share on other sites More sharing options...
cdcoxwell Posted June 25, 2004 Author Report Share Posted June 25, 2004 Mullet, look 4 post back . I did and shee will not idle. Quote Link to comment Share on other sites More sharing options...
PUSH THE THROTTLE Posted June 25, 2004 Report Share Posted June 25, 2004 CD to add to what I said before the reason in checking your pilots is because when you start your shee as long as you don't start it holding the throttle open you are only getting fuel through the pilot jet. From reading your other posts it sounds like a lack of fuel. Your main jet sounds reasonable since it runs until you let off the throttle. You have good spark and reasonable compression. Turn your air screw 2 turns out from seated and as long as your pilots not plugged you should get it to fire. Good luck, I gotta go. Quote Link to comment Share on other sites More sharing options...
svtkid78 Posted June 25, 2004 Report Share Posted June 25, 2004 Once it started after you pulled it would it run with you giving it gas. Then die when you let it idle? Quote Link to comment Share on other sites More sharing options...
cdcoxwell Posted June 25, 2004 Author Report Share Posted June 25, 2004 Ok Push, I understand what you are saying now. Going out side now to try that. I'm back. Shee was 1 and a half turns out so I turned the air screw till seated and backed out 2 full turns. Still nothing. As before shee would quit as soon as I let off the throttle. Now with 2 turns out, shee goes dead a sec. later. So, I believe you are on to something. The air screw, I believe, is for fine tuning. Do I need to bother with turning the screw out more or change the pilot get . I was told to change the pilot jet, I called my buddy at the steelership, because the air screw was not designed to correct problems but to only fine tune the carbs. What do you think?? Yea svtkid, once let go of throttle, shee would go dead and not even try to idle. Thx Cary Quote Link to comment Share on other sites More sharing options...
