yan Posted May 25, 2004 Report Posted May 25, 2004 if no one knows what to do just say so, so i dont keep posting over and over again i have tr6 pipes and a pro design air filter the tr6 pipes came with these little 1" air holes thing to put into the air box and there is 12 of them to put in when every thing was installed in the air box and the pipes the local atv shop jetted the atv with that air intake and what not so my question is that if i put tape over the air hole things so i can go in water and mud just for a day or two do i have to rejette Quote
pimp559 Posted May 25, 2004 Report Posted May 25, 2004 You can cover the holes no problem. If anything it will run a little richer. You might notice a small difference in power but probably not. Quote
sredish Posted May 26, 2004 Report Posted May 26, 2004 You can cover the holes no problem. If anything it will run a little richer. You might notice a small difference in power but probably not. just try it and see. like pimp said, it will just run richer, and best case scenario, it will run a little cooler and have a tad less power (maybe not even noticeable), and the worst case is, you foul a plug. I'd suggest covering the holes and go out for a ride before you go to see if your gonna be having any plug problems or sputtering. My bet is you'll be fine. Quote
yan Posted May 27, 2004 Author Report Posted May 27, 2004 thank you anyone else have any more information Quote
dirttrack25 Posted May 27, 2004 Report Posted May 27, 2004 hello I have 12 of these also..I wouldnt worry about getting mud or even water in the vents unless ur really gonna have it that far under water, but would u really do that to ur shee? I know i wouldnt thats what the honde ute is for Quote
