brandon91 Posted May 22, 2004 Report Posted May 22, 2004 a buddy of myne can get air plane fuel it is 110 octane and much cheaper than 110 from the gas station but i have herd that it is leaded? can i run it in a shee? will it hurt anything? thanks brandon Quote
U8RSAND-Az Posted May 22, 2004 Report Posted May 22, 2004 You can run it without worry but it is not the same as a good quality race gas such as V.P.. Race gas will make more horsepower and run cooler than AV gas. Quote
jeepman380 Posted May 22, 2004 Report Posted May 22, 2004 (edited) I heard that AV gas is bad. Don't know why. I think cause it doesn't have any added chemicals or lubricants like VP adds to their gas so it really isn't as good I don't think. I don't know where you buy your gas from but around here I can get it for $3.50 a gallon which I think is cheap, but maybe i'm wrong cause i've never seen it any cheaper around here. Edited May 22, 2004 by jeepman380 Quote
Rescuejeff Posted May 22, 2004 Report Posted May 22, 2004 I run 50/50 av gas and super, with a little more mix and it runns fine. Quote
brandon91 Posted May 23, 2004 Author Report Posted May 23, 2004 i can get this av gas for 2.05 a gallon because at the airport they sign a year long deal that prices wont change and for me to get torco 110 at the station it is 4.95 a gallon so i might try to mix it 50 50 like rescue jeff sid any why would it be bad i think it has some lead in it is that ok? Quote
2004LEBanshee Posted May 24, 2004 Report Posted May 24, 2004 $4.95 a gallon Dam, I get TORCO MACH 110 for $3.50 a gallon. Quote
