nickxc Posted May 21, 2004 Report Share Posted May 21, 2004 does anyone else use amsoil series 2000 or dominator?? I been mixing 32:1 and the gallon jug says 50:1 premix so I've been thinking of going a little leiner 36:1 or 40:1. I run wideopen for long distances some times (5 miles) so I dont want to go all the way to 50:1 Im worried that wont be enough. any ideas???? Quote Link to comment Share on other sites More sharing options...
rebelbanshee2 Posted May 21, 2004 Report Share Posted May 21, 2004 Amsoil 2000 is the stuff. run it at 50:1 you wont have problems. some people run it at 100:1 Quote Link to comment Share on other sites More sharing options...
Holyman Posted May 21, 2004 Report Share Posted May 21, 2004 Read the bottle, mix it up and ride. I run the 100:1 Sabre stuff at 80:1 and rode it all winter wide open with no jetting changes at all. The Dominator oil is made to be run at 50:1 for highly modified engines. There should be no need at all to run with a higher oil content. Quote Link to comment Share on other sites More sharing options...
Meat_Head Posted May 21, 2004 Report Share Posted May 21, 2004 I have been running Amsoil 2000 series at 50:1 for 3 years now and it works great. Quote Link to comment Share on other sites More sharing options...
nickxc Posted May 22, 2004 Author Report Share Posted May 22, 2004 ok now if I change my mix ration from 32:1 to 50:1 or maybe 40:1 (Im a little nervous) then I will have to rejet also correct?? I will be allowing more fuel in so I will cause a rich condition correct???? Quote Link to comment Share on other sites More sharing options...
Meat_Head Posted May 22, 2004 Report Share Posted May 22, 2004 I will be allowing more fuel in so I will cause a rich condition correct???? Correct. Quote Link to comment Share on other sites More sharing options...
Timmy301 Posted May 22, 2004 Report Share Posted May 22, 2004 Im also using the Dominator oil from Amsoil 50:1 works great. The weedwacker seems to like it too!! I run that sucker wideopen to cut some of the shit growing around the house,no problems yet. Quote Link to comment Share on other sites More sharing options...
PlaynSand Posted May 22, 2004 Report Share Posted May 22, 2004 The Amsoil series 2000 and the Dominator are the same oil , Amsoil just recently renamed the oil Dominator , I use this oil at 50:1 and I have not had any problems from the banshee , other than it keeps the plugs so clean it is hard to read them. I have been using the Dominator in my Polaris oil injection tank and I think it is a 40:1 ratio and it has not had problems , So 40:1 ratio works also. Quote Link to comment Share on other sites More sharing options...
nickxc Posted May 22, 2004 Author Report Share Posted May 22, 2004 ok Im gunna do it... im nervous but if you guys say its ok then Ill try it. I'll prolly go 40:1 Im just worried about holding it wide open for long periods. I will ride it then prolly jet down to compensate for the added fuel. Quote Link to comment Share on other sites More sharing options...
rebelbanshee2 Posted May 22, 2004 Report Share Posted May 22, 2004 you will not have a problem at 50:1 trust us. I have 4mm stroker running race gas that i absolutly hammer on, no problems. the oil is made to be run at 50:1 dont worry about it. Quote Link to comment Share on other sites More sharing options...
cam2 Posted May 22, 2004 Report Share Posted May 22, 2004 don't worry about it. run it at the recommended 50:1 ratio. the most important thing is that you're JETTED PROPERLY for running WOT for long distances. amsoil is good oil, the 2000 oil is designed for severe racing conditions so if you're JETTED PROPERLY you won't have any problems, atleast not from the oil. when i first started using 50:1 2000 oil i was nervous as well but no longer, as long as they continue to sell it i'll continue to use it with confidence. Quote Link to comment Share on other sites More sharing options...
nickxc Posted May 23, 2004 Author Report Share Posted May 23, 2004 Im gunna mix up 5 gallons of 50:1 and hammer down then... I gotta trust you guys. If shee doesn't blow with in this 5 gallons sheell be fine Ill hammer it hard just to get my fears out of the way. thanks guys !!!!! Quote Link to comment Share on other sites More sharing options...
