Banshee Pilot Posted May 20, 2004 Report Share Posted May 20, 2004 I currently have a set of Skate II's on my Banshee and am looking to buy a set of Haulers. I was just curious as what the difference is performance-wise in running a 20x10 paddle as opposed to a 22x10. What do you fellas prefer and why? -Craig Quote Link to comment Share on other sites More sharing options...
wesw Posted May 21, 2004 Report Share Posted May 21, 2004 22 would be taller hince more top speed but will take longer to get there since you would be higher gears. 20 are what i run Quote Link to comment Share on other sites More sharing options...
Lepew Posted May 21, 2004 Report Share Posted May 21, 2004 I run 20-10 but I like playing not the drags. Some guys like the 22's for the added ground clearence for steap tree shots. Quote Link to comment Share on other sites More sharing options...
Minkia38 Posted May 21, 2004 Report Share Posted May 21, 2004 what they said 22" require more power to turn but have more top end Quote Link to comment Share on other sites More sharing options...
sredish Posted May 21, 2004 Report Share Posted May 21, 2004 but you could always regear your sprockets for same final gear at the tires, therefore providing the same performance you have now, minus a c-hair for the extra weight of the tires, not even noticeable. I run 20s because that's the same as my dirt tires, so I don't have a lot of sprocket changing. Quote Link to comment Share on other sites More sharing options...
Cotton eyed Joe Posted May 21, 2004 Report Share Posted May 21, 2004 but you could always regear your sprockets for same final gear at the tires, therefore providing the same performance you have now, minus a c-hair for the extra weight of the tires, not even noticeable. I run 20s because that's the same as my dirt tires, so I don't have a lot of sprocket changing. Thats exactly why I run 13/44 right now. I did it because I'm going to be running 21" 8's soon, but 22" would put me almost at stock top speed. I'm looking for more quickness than all out top speed. If the 8's arent enough to hook me up with the low gear ratio, then I'll go 9's. Quote Link to comment Share on other sites More sharing options...
