I just picked my needle up one notch. She runs alot stronger in the mid and top but sputters in the bottom. I turned my airsrews out to 3 turns and it helped quite a bit. But I dont want to go too far. I ordered 27.5 pilots, the dealer called and said they were in BUT they only ordered ONE. banghead
So I have to make due for the weekend.
320 mains,needle 4th from top, 30 pilots for now.
Idealy you want your idle/air screws to be 1.5 to 2 turns out. Seems that you already are doing the right thing by changing the pilot jets...once you get the 27.5's in turn your air screws back to 1.5-2 turns out and adjust as necessary from there. ;)
Just to make sure. I always like a second opinon. If yah can start with out the choke it's a little rich on the pilot wich would cause a garguling sounding bog in second out of power. cause it not to rev real quick
