nickxc Posted May 20, 2004 Report Share Posted May 20, 2004 I dropped one of my slides straight down on the cement and bent one of my needles. I bent it back but it was still a bitch to get back into the carb will this be ok or should I get some new needles???? If I get new needles there is no sence and getting stock ones since they are like $20 each but what kind should I get... vitos, toomey, ??? Thanks!! Quote Link to comment Share on other sites More sharing options...
Basicorpse Posted May 20, 2004 Report Share Posted May 20, 2004 I would definetly get new needles if I were you. You dont want them binding up in there. I have a set of toomey needles in my carbs and I am very happy with them. Quote Link to comment Share on other sites More sharing options...
sredish Posted May 20, 2004 Report Share Posted May 20, 2004 I would definetly get new needles if I were you. without a doubt. most of them will be fine. just get a new one that's not bent. Quote Link to comment Share on other sites More sharing options...
boonman Posted May 20, 2004 Report Share Posted May 20, 2004 I straightened a needle once. It didn't work worth a shit. Get a new one. And be careful.... Quote Link to comment Share on other sites More sharing options...
Banshee Pilot Posted May 20, 2004 Report Share Posted May 20, 2004 I have Vito's in my Banshee. I'm happy with them, but I'm not sure they're any better than any other needle. -Craig Quote Link to comment Share on other sites More sharing options...
frocashmoney24 Posted May 20, 2004 Report Share Posted May 20, 2004 def get new ones, go to the dealer to get a new one, make sure the 2 you have are the same size! Quote Link to comment Share on other sites More sharing options...
Justintoxicated Posted May 21, 2004 Report Share Posted May 21, 2004 I straightened both my needles...I just bent them back and rolled them along the table to make sure they were true. I don't know why this wouldnet work.. Quote Link to comment Share on other sites More sharing options...
nickxc Posted May 21, 2004 Author Report Share Posted May 21, 2004 is there any advantage to vitos or toomey needles over stock or should I just get stock needles???? Quote Link to comment Share on other sites More sharing options...
Justintoxicated Posted May 21, 2004 Report Share Posted May 21, 2004 (edited) I would go for the toomy ones..>So you could not bend it back? If you can bend it back perfectly straight you should not have any problems...you can just work it around on a flat table... Why does everyone just say buy new needles? Hey are so expensive for what you get... I believe the toomy's and vitos have a different taper that will affect your mid-throttle jetting. Edited May 21, 2004 by Justintoxicated Quote Link to comment Share on other sites More sharing options...
MILO Posted May 22, 2004 Report Share Posted May 22, 2004 one of mine was slightly bent, and i straightened it out and haven't had any problems with it since. that was almost 2 years ago. but i've also heard that other brands need set up differently due to different lengths and thicknesses. Quote Link to comment Share on other sites More sharing options...
