Hockey390 Posted May 20, 2004 Report Share Posted May 20, 2004 since I have my jugs off and I'm going up a bore, what do you all suggest i do.. whats the difference between porting, and boring? What about polishing, what will give me what i need (to go up a bore) and give me performance? What is the cheapest way? what is the most expensive? give me some ideas to throw around... taking the jugs in tomarrow to have the work done. Quote Link to comment Share on other sites More sharing options...
Justintoxicated Posted May 20, 2004 Report Share Posted May 20, 2004 (edited) Porting is usualy enlarging and reshaping your intakes and transfers to flow more fuel and air. Big Difference. Boring is just making the cylinder one size larger, but the intakes transfers and exhaust are not changed so you are not really flowing much more than before. Polishing is basicaly removing all the factory blemishes and casting flaws, it helps but not as much as a Port+polish...I guess you could just polish it, but If I was going to do that i would go ahead and get it ported too... Then you can enjoy more gains later from carbs and reeds too. Typicaly I believe most places bore it a size or two over to get rid of any harmfull burs left from the porting so you would want to do this before you bore it out. Edited May 20, 2004 by Justintoxicated Quote Link to comment Share on other sites More sharing options...
frocashmoney24 Posted May 20, 2004 Report Share Posted May 20, 2004 he nailed it, go with the port n polish, big gains that u will definalty notice, the only bad thing is, it aint cheap Quote Link to comment Share on other sites More sharing options...
Hockey390 Posted May 20, 2004 Author Report Share Posted May 20, 2004 how much am i looking at... The shop said $80 for both jugs to bore it... Then again I could call and ask.. Quote Link to comment Share on other sites More sharing options...
MULLET~BOY Posted May 20, 2004 Report Share Posted May 20, 2004 your looking at 450 bucks for a good mx style porting Quote Link to comment Share on other sites More sharing options...
boonman Posted May 20, 2004 Report Share Posted May 20, 2004 Yep, $450-$500 for porting, and a bore job. You have to bore the cylinders after porting anyways, so why not port it before you bore it.... Quote Link to comment Share on other sites More sharing options...
Hockey390 Posted May 20, 2004 Author Report Share Posted May 20, 2004 lol, i accidently splurged... took my jugs in to have them bored, left with a smile... Unfortunatly I talked myself into port, polish, bore, and having them assemble it...mainly just because I want it to run RIGHT.. When it comes to engines, I love to work on them, but when they arent working and i'm spending money to get it fixed... If i dont have somene next to me that can make sure i dont mess up, I choose the pro's... Sorry if I let you all down Quote Link to comment Share on other sites More sharing options...
boonman Posted May 20, 2004 Report Share Posted May 20, 2004 Who is going to port it? Make SURE you go with someone reputable. Don't have your local shop do it. Unless you live next door to Jim in Tulsa Oklahoma.. Quote Link to comment Share on other sites More sharing options...
Hockey390 Posted May 20, 2004 Author Report Share Posted May 20, 2004 A place called bridgeview powersports. A guy that lives with my aunt in cali has them do his work, he said they do an A+ job... They just did port work for a guy on his banshee last week and they said it was F*ing ripping! Is there such a thing as a bad port & Polish job? I'm sure it can not be worth it AS much, but is there such a thing as a bad one...? Quote Link to comment Share on other sites More sharing options...
rebelbanshee2 Posted May 20, 2004 Report Share Posted May 20, 2004 Im sure there are bad port jobs, like hacking them up with a 1" end mill would be a bad port job, but a small performance shops porting wont make things any worse but you may not get as much for your money if you went with one of the really good shops like passion or patriot. either way i dont think you will be dissapointed in it Quote Link to comment Share on other sites More sharing options...
Master of Faster Posted May 20, 2004 Report Share Posted May 20, 2004 Hockey, lemme know how he does on the port/polish on yours. I live in Auburn, pretty close to Midland. If he does a good job it might be worth having someone local do mine. It's my understanding that he was the head mechanic for Bridgeport Polaris until they got closed down for warranty fraud, and was pretty good but I didn't know he did work like that, lemme know. Quote Link to comment Share on other sites More sharing options...
reas11 Posted May 20, 2004 Report Share Posted May 20, 2004 since I have my jugs off and I'm going up a bore, what do you all suggest i do.. whats the difference between porting, and boring? What about polishing, what will give me what i need (to go up a bore) and give me performance? What is the cheapest way? what is the most expensive? give me some ideas to throw around... taking the jugs in tomarrow to have the work done. from what i heard it isn't smart to get 2 strokes polished .. Quote Link to comment Share on other sites More sharing options...
Justintoxicated Posted May 21, 2004 Report Share Posted May 21, 2004 rease you can polish the exhaust port and get rid of the factory casting flaws (not polished but evened down some) I think thats what they consider polishing...The thing with porting is that it can usualy only be done once, so you want to make sure you get a good job, like from jim at passion. Quote Link to comment Share on other sites More sharing options...
MULLET~BOY Posted May 21, 2004 Report Share Posted May 21, 2004 you polish exughst ports you want the intakes and transfers ruff so that the fuel can atomiz polished exughst just makes sure that you won't get carbon build up i have heard of a couple builders using coatings in the exughst now to lower engine temps but yet still stop carbon build up jethro Quote Link to comment Share on other sites More sharing options...
