What Top End Work?
since I have my jugs off and I'm going up a bore, what do you all suggest i do.. whats the difference between porting, and boring? What about polishing, what will give me what i need (to go up a bore) and give me performance?
What is the cheapest way? what is the most expensive? give me some ideas to throw around... taking the jugs in tomarrow to have the work done.
Porting is usualy enlarging and reshaping your intakes and transfers to flow more fuel and air. Big Difference. Boring is just making the cylinder one size larger, but the intakes transfers and exhaust are not changed so you are not really flowing much more than before. Polishing is basicaly removing all the factory blemishes and casting flaws, it helps but not as much as a Port+polish...I guess you could just polish it, but If I was going to do that i would go ahead and get it ported too...
Then you can enjoy more gains later from carbs and reeds too. Typicaly I believe most places bore it a size or two over to get rid of any harmfull burs left from the porting so you would want to do this before you bore it out.
Edited by Justintoxicated
lol, i accidently splurged... took my jugs in to have them bored, left with a smile...
Unfortunatly I talked myself into port, polish, bore, and having them assemble it...mainly just because I want it to run RIGHT.. When it comes to engines, I love to work on them, but when they arent working and i'm spending money to get it fixed... If i dont have somene next to me that can make sure i dont mess up, I choose the pro's...
Sorry if I let you all down :flush:
A place called bridgeview powersports.
A guy that lives with my aunt in cali has them do his work, he said they do an A+ job... They just did port work for a guy on his banshee last week and they said it was F*ing ripping!
Is there such a thing as a bad port & Polish job? I'm sure it can not be worth it AS much, but is there such a thing as a bad one...?
Im sure there are bad port jobs, like hacking them up with a 1" end mill would be a bad port job, but a small performance shops porting wont make things any worse but you may not get as much for your money if you went with one of the really good shops like passion or patriot. either way i dont think you will be dissapointed in it
Hockey, lemme know how he does on the port/polish on yours. I live in Auburn, pretty close to Midland. If he does a good job it might be worth having someone local do mine. It's my understanding that he was the head mechanic for Bridgeport Polaris until they got closed down for warranty fraud, and was pretty good but I didn't know he did work like that, lemme know. ;)
from what i heard it isn't smart to get 2 strokes polished ..
rease you can polish the exhaust port and get rid of the factory casting flaws (not polished but evened down some) I think thats what they consider polishing...The thing with porting is that it can usualy only be done once, so you want to make sure you get a good job, like from jim at passion.
you polish exughst ports you want the intakes and transfers ruff so that the fuel can atomiz polished exughst just makes sure that you won't get carbon build up i have heard of a couple builders using coatings in the exughst now to lower engine temps but yet still stop carbon build up
jethro
