Shee Wont Run Edit
hey, just wanted to start a new topic cause that one has soooo much stuff on it.
http://www.bansheehq.com/forums/index.php?...opic=28553&st=0
that was it...
Just pulled the pipes off, and I got a suprise... APPRX. 1/2 gallon of came out of each pipe.. EACH PIPE
here are pics....
I think that is my problem. Compression wise, maybe still low...who knows, but I'm airing them out, here are pics..
thats the floor....took one off and went to set it down...ALL OVER!
this is the bucket from half of one...
nother of the floor...
Think this is why I have spark, gas, and no spark???
***EDIT***
sorry, meant spark, gas, and no fire...
Edited by Hockey390
Yeah, one of the float valves in your carbs must have stuck open
and you must also have a problem with one or both of your overflow
tubes. Pinched, kinked or otherwise plugged up. Make sure you clear
your overflow tubes so this doesn't happen to you again.
I'll third the notion about stuck needle valves and clogged overflows. My tecate4 used to have the fuel run right through the motor like that. The first time I didn't know and got it actually started, it sprayed everywhere out the silencer. That sounds like a potential.
I would take the tank and tank plastic off of that bike and turn it upside down with the plugs out and turn it over a couple of hundred times. :-) This will get that crap out of your bottom end. Clean your carbs and check the float bowl levels and needle valves. Then put that thing back together and see if you can get it to start. Good Luck.
