Losing Coolant
Yeah I changed the side cover and water pump gaskets, also relocated the resevior where fixit rod said to. the temp dropped from 220 to 165 and I didn't lose a drop of coolant. Thanks for the info.
I didnt have any problem with overheating when the overfill tank was in the stock position but I moved it anyways to the front and now when I run full throttle, even just for a couple of seconds when I come to a stop or just slow down, it is smoking pretty bad out of the exhaust and is usually hot coming from the motor, if I just cruise around for about a minute it cools back down and stops smoking. What could be wrong. It shouldnt be lean or rich, I havent done any mods except for that overfill tank. Brad. :blink:
