Help Hole In Case
It really depends on what kind of bike you have. If you have a beater that will need a rebuild sometime in the future, JB it for now and get it welded when you tear it down.
If you have a show piece, get it welded now. Nothing like seeing a pimp ride with some jb hanging off of the case.
As for the coolant in your oil, I doubt it is coolant. Your oil would drain out foamy white if your oil had coolant in it. Probably just fresh oil.
depending ont he size shape and location of the hole
i would drill it out to a clean round hole and tap it
put a socket cap set screw in it with soem loctite to seal it up with
if you use an old half worn out tap it will be a night tight fit between the threads
or use a pipe tap and tap it for say a 1/8 inch pipe plug
i dont see why this wouldnt work just fine depending ont he location of the hole
Good idea except it would introduce fine shavings of aluminum into the case. It would only work if you tore the motor down. If you tore the motor down, you might as well spend the $20 and get it TIG welded.
