SiCkBaNsHeE_990 Posted May 19, 2004 Report Share Posted May 19, 2004 I just my dynoport 2 into 1 pipe in from someone that i bought it from. Anyways i got it on and its leaks. I got the o-ring on there and there is still space and i cant push it up on the port anymore. Anyone had this problem and got any suggestions? Quote Link to comment Share on other sites More sharing options...
FadedDreams Posted May 19, 2004 Report Share Posted May 19, 2004 I might be wrong,but i think with those pipes they need some type of high temp silicone applied to be leakproof.Maybe someone else can give you a better idea on that. Quote Link to comment Share on other sites More sharing options...
SiCkBaNsHeE_990 Posted May 19, 2004 Author Report Share Posted May 19, 2004 ya i was thinking about that also. anyone else got any suggestions Quote Link to comment Share on other sites More sharing options...
Holyman Posted May 19, 2004 Report Share Posted May 19, 2004 A good thick shmear of silicone on the spigots before you put on the pipe and let it cure before you run it. should work just fine. Quote Link to comment Share on other sites More sharing options...
RIDEKY Posted May 19, 2004 Report Share Posted May 19, 2004 GO TO AUTO ZONE AND GO IN THE BACK WERE ALLTHE MUFFLER STUFF IS AND YOU SHOULD BE ABLE TO FIND THESE BIG THICK RUBBER EXHAUST GASKETS. THEY MIGHT BE RUBBER HANGERS BUT WORKED GREAT FOR ME. BE SURE TO MEASURE YOUR EXHASUT PORT. Quote Link to comment Share on other sites More sharing options...
dalegoldston Posted May 19, 2004 Report Share Posted May 19, 2004 I use teflon pipe tape. Just wrap it around the ports and but up to it, works well for me and is high temp. Quote Link to comment Share on other sites More sharing options...
