canadabanshee Posted May 18, 2004 Report Share Posted May 18, 2004 What can a stock engine take of nos how many shot of nos can you give it. What is the best set up to get. Quote Link to comment Share on other sites More sharing options...
U8RSAND-Az Posted May 19, 2004 Report Share Posted May 19, 2004 I ran an N.O.S. set up for a while, it was a lot of fun but keeping the bottle full is a pain. If it's over full when it gets hot it will blow the pop off valve. As for your engine you need to have the crank trued and welded, this is a must because they tend to move around on a ported engine let alone the harsh abuse the sudden hit of nitrous will give it. Also run a good forged piston I had Pro-X cast pstons in mine and while I never hurt it using the nitrous I did pull the wrist pin through the bottom of one of the pistons several months after we had taken off the nitrous kit. Theres a lot more things I would recomend for it to make a nice set up if you're interested. Quote Link to comment Share on other sites More sharing options...
