Hockey390 Posted May 18, 2004 Report Share Posted May 18, 2004 just trying to get more help on the topic...doesnt seem like anyone knows my problem.. truth is I have NO idea whats wrong.. CDI maybe, but heres the link to the topic...please check it out guys, I'm supposed to go riding thursday.. http://www.bansheehq.com/forums/index.php?...pic=28553&st=0& Quote Link to comment Share on other sites More sharing options...
J..J. Posted May 18, 2004 Report Share Posted May 18, 2004 Try to trace back step by step what you have done to it, from when it did run to when it didn't. Over-oiling of airfilter perhaps? It seems as if you have the basics covered. Similiar thing happened to me a while back, couldn't start it, ended up pulling her with the truck and bump starting. Ran and started fine ever since, go figure... Quote Link to comment Share on other sites More sharing options...
Hockey390 Posted May 18, 2004 Author Report Share Posted May 18, 2004 I didnt do anything to it... It started, ran strong, shut it off...went ot start the next day and there was nothing! Quote Link to comment Share on other sites More sharing options...
J..J. Posted May 18, 2004 Report Share Posted May 18, 2004 Dunno man, have you tried bump starting her? Quote Link to comment Share on other sites More sharing options...
94BansheeRider Posted May 18, 2004 Report Share Posted May 18, 2004 (edited) Does it still have the stock CDI? Mine finally gave out after 9 years, about an hour of riding one day. Shut off the bike, then went back to start it and no go. Wouldn't even pull start. The CDI had fried. Sound like your problem could be the CDI or maybe the plug CAPS need replacing. Good Luck. Edited May 18, 2004 by 94BansheeRider Quote Link to comment Share on other sites More sharing options...
Hockey390 Posted May 18, 2004 Author Report Share Posted May 18, 2004 ya, but i have spark... and a solid spark at that. my compression is about 110 on both. Quote Link to comment Share on other sites More sharing options...
jcharne Posted May 19, 2004 Report Share Posted May 19, 2004 i know this sounds dumb but since you haven't run it in a year check to see if your exhaust isn't plugged. maybe something made a nest in there. i bought a 125 years ago and it wouldn't run. after i traded to a friend he found out the exhaust was plugged Quote Link to comment Share on other sites More sharing options...
SANDSTAR Posted May 19, 2004 Report Share Posted May 19, 2004 Sounds like time to take her in for a tune up by a good shop. That was a long thread covering everything known to man. Forcing it will only make the problem worse. Ask alot of questions when you take it in. Make sure you understand what the problem was and how to fix it the next time it happens. If it dosen't start in a couple of kicks, somthing isn't right. Good luck, and keep those banshee gremlins in Michigan. Quote Link to comment Share on other sites More sharing options...
