Mike C Posted May 17, 2004 Report Posted May 17, 2004 I have found two sets of carbs one set 36-38mm lectron carbs w/ dual power jets the other kehin pwk39 single power jet converted by tyson racing. Could i use either of these or would they be to big. My banshee is punched 20 out,nosshead 20 cc domes,t-5's, V-force reed set up. What do ya'll think could work or to big. Thanks mike clark Quote
mercado111 Posted May 17, 2004 Report Posted May 17, 2004 To big. You need 28-30mm or stay with stock. 38, 39, 40 are for ported motors, thats my opion. I have 28mm on my girl friends patriot racing duner port banshee. They work great. I was only running 35mm on my +4mm stock set up. Quote
Mike C Posted May 18, 2004 Author Report Posted May 18, 2004 (edited) Alcohol carbs not gas carbs i think you thought i was talking about gas carbs. Edited May 18, 2004 by Mike C Quote
mercado111 Posted May 18, 2004 Report Posted May 18, 2004 I was refering to alky. My 35.5mm mikuni's can be switched from gas to alky and back by replacing the dump tubes. I was running a +4mm stroker drag ported with v-force reeds, 18cc domes +8 timing and my 35.5mm worked great. You did not state that you banshee was ported, so I assume it is not. I think running that big of a carb would be a little much. If you get some port work done they might work, but get with your builder and he will recomend the right size carbs to use. Quote
