jeepman380 Posted May 17, 2004 Report Share Posted May 17, 2004 I bought a new 200 watt stator and installed it and after riding it for a few short moments it just quit. I had an idea of what it was so I changed my FMF CDI with a stock one and it fired right back up. Then I put the FMF one back on and nothing. I was just wondering why this happened? Could it of just been cause of the extra wattage or something? Well on the brighter side of things I ordered a Dyna Ignition CDI and should be here shortly . Quote Link to comment Share on other sites More sharing options...
Indubitably Posted May 17, 2004 Report Share Posted May 17, 2004 Where did you buy the stator, it might have needed a voltage regualtor or some sort of regulator thing. That may have caused your cdi to go out, but i don't know for sure. Quote Link to comment Share on other sites More sharing options...
jeepman380 Posted May 17, 2004 Author Report Share Posted May 17, 2004 I bought it from www.rickystator.com. He didn't say anything about needing a voltage regulator. If it blew out the FMF box why didn't it blow out the stock one too? Quote Link to comment Share on other sites More sharing options...
BenBB Posted May 17, 2004 Report Share Posted May 17, 2004 The higher wattage stators don't change the voltage/wattage to the ignition circuit, only the lighting circuit, and the two are completely separate so chances are your FMF just happened to go out shortly after you put in the stator. I think FMF quit making those AOF ignitions so it may be a common problem. On the upside, I've had excellent luck with my Dyna so hopefully you should be set... Quote Link to comment Share on other sites More sharing options...
jeepman380 Posted May 18, 2004 Author Report Share Posted May 18, 2004 Thanks for the info guys! Quote Link to comment Share on other sites More sharing options...
