adeezy9183 Posted May 19, 2004 Author Report Share Posted May 19, 2004 i just put the new top end on (bored .60 over) THANKS KYLE. haven't fired her up yet because i need some plugs and some oil, and DEFINITELY larger jets for the carbs because if i let this happen again i'll whip my own ass . i'll let you guys know how everything works out. one more question, could this lean condition cause the motor to be hard starting and make it not idle whatsoever because when i first got it, it ran fine, started right up and when it started acting up, the idle screw had no affect on the idle and it was hard as hell starting. thanks a lot guys. hey kyle how is that t-maxx? Quote Link to comment Share on other sites More sharing options...
dirtbike killer Posted May 20, 2004 Report Share Posted May 20, 2004 (edited) Your main isn't doing much when your trying to kick it over. If its hard to start when its cold, but easy to start when its warmed up, your pilot is to small. If starts easy with no choke when its cold, but is hard to start when its warm, then the pilot is to big. Make sure you have no air leaks before you mess with the jets. Edited May 20, 2004 by dirtbike killer Quote Link to comment Share on other sites More sharing options...
cgamla Posted May 20, 2004 Report Share Posted May 20, 2004 I have a similar set up and I can tell you that your main is not big enough. I am at sea level also. You should be running a 185 at least with your needle some where in the middle grooves. I ran mine with that jetting and it wore out really fast. Theres a good chance you need to go up on the pilot to. Quote Link to comment Share on other sites More sharing options...
adeezy9183 Posted May 20, 2004 Author Report Share Posted May 20, 2004 just put her back together and put a 185 main in. i am still running the 48 pilot and haven't moved the needle. it starts and idles fine now. no problems at all. now all igotta do is break her in real good and get rolling. what do you guys suggest when breaking it in? Quote Link to comment Share on other sites More sharing options...
