Larger Carbs
DIABLO BANSHEE
has anyone out there ran 28 or 30 mm. carbs?i have a mid range mx port,boysen rad valves toomey T-5's and run a two into one air filter,i'm putting out 58 hp at the rear wheels at 9750rpm and 36ft/torque at7750 rpm.i motocross this bike and sand ride i want more hp but still be ridable,and 34or35mm. will drowned out this motor the way it's built.if you've ran the 28 or 30's let me know how you liked them and how you set them up jetting wise. if you would like to see the dyon results i can e-mail them to you,it was done by carlos at CG Performance in san diego:evil: :evil:
Edited by DIABLO BANSHEE
You need to talk to your porter and see if the motor will have enough velocity to run like it should with 34's. my duncan national motors were killer with 34 pj's, but sucked with 28's or 30's. The motor i have now is ported for 28's, but once i break it in and ride it for a while i plan on trying it with 34 pj's. If you get a 34 i recommend a 34 or 35 pwk, there soooooo much easier to tune than a pj. pm me your dyno sheet, i'd like to see it. banchetta's is a nice bell shape before he got a stroker.
what's your set-up, i'll try to help an anyway i can.
tat2
Edited by tats4life
I'm running two 28mm pwk's, I pretty much have my motor built to the carbs. I don't know how much power my shee's making, but it's alot. The 28's arn't much bigger then the stock 26's but they are a hell of a lot better and way easy to tune. I like them..I've had them for years now and they work like a champ.
i'm running 30mm rs carbs i like them i have the portwork to go to a bigger carb, but actually in all honesty i'm satisfied with the lowend i get from using 30mm. and my pipes allow for the topend pull.. i think u should consider using rs carbs if u want the lowend and if u want more pull on top change your pipes up consider getting your flywheel lightned .. advancing your timing and porting your cages .. theres so many possibities u can do to increase your hp . right now my bike is nowhere near an mx bike but with my port, 30mmrs carbs , ported stock reed cages, timing advanced +4 deg. im at sea level and im right at a 370 main with the needle at the 3rd clip.. one thing to consider if u decide to get rs carbs is that u need a bigger pilot jet then u would with fs or ds carbs .
