CarlosD Posted May 12, 2004 Report Share Posted May 12, 2004 Hey guys Im looking to upgrade my lighting on my 1995 Banshee. What does the factory stator support? The lamp kit Im looking into is rated at 35 watts a bulb so 70 watts total. Would I be able to use this without getting the stator rewound? Quote Link to comment Share on other sites More sharing options...
sredish Posted May 13, 2004 Report Share Posted May 13, 2004 (edited) Hey guys Im looking to upgrade my lighting on my 1995 Banshee. What does the factory stator support? The lamp kit Im looking into is rated at 35 watts a bulb so 70 watts total. Would I be able to use this without getting the stator rewound? Yes, 2 35 watt bulbs on the front will pretty much do it. I run Hella 500s on mine and before I could afford a 200 watt stator, I just ran 35 watt H3 bulbs in it, the lighting was better than stock with the better Hella housing. You can get 35watt H2 bulbs, just do a search. Scott Edited May 13, 2004 by sredish Quote Link to comment Share on other sites More sharing options...
