Basicorpse Posted May 13, 2004 Author Report Share Posted May 13, 2004 Yea I ended up orderin one off fleabay as well. Does anyone know how much stiffer the barnett clutch springs are than stock? Should I use all 6 barnett springs or use 3 barnett and 3 stock? Quote Link to comment Share on other sites More sharing options...
jrm312 Posted May 13, 2004 Report Share Posted May 13, 2004 i have 3 and 3 of the barnett dirt diggger in mine and like but it dosent bit like it would if i had all 6 in their, but then again sore fingers or clutch slip alittle your choice. Quote Link to comment Share on other sites More sharing options...
Basicorpse Posted May 13, 2004 Author Report Share Posted May 13, 2004 (edited) How do you like your barnett clutch? My buddy told me that I should be able to put more power to the wheels now due to the clutch slipping less. I'll probaly end up doing half stock springs and half of the barnett springs. I dont really have enough mods to justify having an insanely stiff clutch. Edited May 13, 2004 by Basicorpse Quote Link to comment Share on other sites More sharing options...
jrm312 Posted May 13, 2004 Report Share Posted May 13, 2004 i like it alot, its only my second clutch, so from stock it hole lot better, but i got some mods so you need it , im going to put all six back in . but you should be fine with 3 and 3 my barnett came with 2 sets stock and heavy duty and their stock are better then oem springs. so good luck make sure you line up the arrows on the clutch cable. Quote Link to comment Share on other sites More sharing options...
