I dont have the spark arrester.
But the hush kit really does HUSH alot.
I noticed no powerloss whatsoever. infact it feels a bit stronger in the midrange but does top off a slight bit earlier.
i have seen that pic but but how i was taking what there site says is your put a clamp on sparkey on to the tip of the hush kit is this true that is what i wanted to see if it looks f :cheers: unny
Maybe this image will work... this the hush kit I mounted on my FMF power core 2 silencers. Let me know if these pics don't work. I'll move them to a different server if they don't. spark%20hush.jpg
can you give some info on how mounted that to the FMF silencers?
Can you give some info on how mounted that to the FMF silencers?
Yeah I made those aluminum end caps out of 3/4" thick 6061 T6 plate. The tubes that go into the hush kit have a round flange that I drilled 3 holes in a radial pattern. I drilled and tapped holes in the end caps and screwed the tubes in there with stainless steel bolts. Did a few other minor things to get them to fit and bolted everything back together. I didn't want to buy the Turbine cores as they were 240 or so from the stealership. The hush kit only cost me 170 and the other materials were about 10 bucks.
