Percy Posted May 10, 2004 Report Share Posted May 10, 2004 Hi, I am repacking my silencers on my 01 Banshee, which I have had for a month. They are DG pipes, which were put on by the previous owner. When I opened the silencers, I see the core (perforated) that runs in the silencer is not in very good condition. On one pipe the core is actually broken and has been sort of held together by the silencer packing material. Do i need to get new cores, or can I clean up the existing ones, and make sure they are straight and no holes are blocked up, repack them and rebuild the silencer? Must the core join tightly onto the pipe coming into the silencer and then also tightly into the pipe leading out the back of the silencer? Thanx for any help Bruce Quote Link to comment Share on other sites More sharing options...
frocashmoney24 Posted May 10, 2004 Report Share Posted May 10, 2004 yea it should be pretty tight in the front and the back, u could try to rebuild it if u hve some welding skills, then repack it, i dont think blockin a few on the holes in the mesh is gonna hurt performance, good luck Quote Link to comment Share on other sites More sharing options...
dogboystoy Posted May 10, 2004 Report Share Posted May 10, 2004 Hey, I took off my silencer caps this weekend (tail pipe), and didnt see any packing material. I did see some sort of device about 6" down the tube. Am I supposed to remove that? Is that where I repack my silencers? Quote Link to comment Share on other sites More sharing options...
frocashmoney24 Posted May 11, 2004 Report Share Posted May 11, 2004 when ur done cleanin out the silencers all thats gona be there, is the outside round alum. part, and the inside metal mesh type part connected to the end cap, then just wrap or pack in the new shit and ur on ur way Quote Link to comment Share on other sites More sharing options...
Percy Posted May 11, 2004 Author Report Share Posted May 11, 2004 "Hey, I took off my silencer caps this weekend (tail pipe), and didnt see any packing material. I did see some sort of device about 6" down the tube. Am I supposed to remove that? Is that where I repack my silencers?" Hey Dogboytoy, Yeah, there should be packing material around the mesh core, that joins the pipe to the end core, in the aluminium silencer end. You can buy new material at any bike shop Cheers, Quote Link to comment Share on other sites More sharing options...
dogboystoy Posted May 11, 2004 Report Share Posted May 11, 2004 (edited) Thank you, Also what do you use to remove that mesh core? Does it pull out easy? Edited May 11, 2004 by dogboystoy Quote Link to comment Share on other sites More sharing options...
Percy Posted May 12, 2004 Author Report Share Posted May 12, 2004 Yes, it puls easy. Just slides out the pipes. When I put it back in, I put a thin pipe in the mesh core, and used this to line up the mesh core with the exhaust pipes. Pulled the thin pipe out when I was finished. Also sealed where the joins are with high heat silicone. Putting the pipes back on this weekend, so will see how much diff it has made. The old packing was really messed, so am hoping it will be much better Quote Link to comment Share on other sites More sharing options...
BansheeBrian Posted May 14, 2004 Report Share Posted May 14, 2004 I thought you were supposed to pack it loose(roughly 3 wraps) so the sound gets absorbed instead of bounced out of the pipe? Quote Link to comment Share on other sites More sharing options...
Percy Posted May 14, 2004 Author Report Share Posted May 14, 2004 On the packing material package, it says it must be wrapped tightly? Can anyone comfirm if it must be tight or loose? Quote Link to comment Share on other sites More sharing options...
frocashmoney24 Posted May 14, 2004 Report Share Posted May 14, 2004 medium, you dont want it so tight the exhaust has a trouble going throught, but not to loose to where it wont do shit, just wrap it moderatley tight Quote Link to comment Share on other sites More sharing options...
