sredish Posted May 16, 2004 Report Share Posted May 16, 2004 Uh, Ur, Yeah I done it berfore. I Aint to proud of it, but it works jus fine. Put the oil in and shake it up right away, then put gas in and shake again. Yeah, I think we've all done it a time or two, or maybe more... like they said, be sure to turn you petcock off, then just put the oil in and then the gas. just make sure you know how much room for gas you have. you'd hate to put x amount of oil in and then not have room for the gas you need for the right mixture. Quote Link to comment Share on other sites More sharing options...
sweetshee4312 Posted May 16, 2004 Report Share Posted May 16, 2004 ur tank doesnt have to be dry, the gas thats int here already should be mixed....So if u add 2 gallons on top of one, and you put 8 Oz of oil in there ur ratio will still be the same, if u ask me, whats wrong with it, it wount mix???how is a gas can any diffrent???? Quote Link to comment Share on other sites More sharing options...
sredish Posted May 16, 2004 Report Share Posted May 16, 2004 (edited) ur tank doesnt have to be dry, the gas thats int here already should be mixed....So if u add 2 gallons on top of one, and you put 8 Oz of oil in there ur ratio will still be the same, if u ask me, whats wrong with it, it wount mix???how is a gas can any diffrent???? well, nothing as long as you take the few precautions mentioned before. Just make sure that when you mix it you have your petcock to the off possition because if you put hte oil and then the gas the oil will sink and possibly go straight to your carb bowls. If that happened, then you'd burn all your oil if it would even run and then be running straight fuel. It's also important to make sure it's mixed well before you take off. If those two aspects are covered, then there's no prob. Edited May 16, 2004 by sredish Quote Link to comment Share on other sites More sharing options...
papa_smurf49319 Posted May 16, 2004 Report Share Posted May 16, 2004 just put the oil in , and then fill up the tank with the gas nozzle that should move it around and mix it enough, i do that all the time Quote Link to comment Share on other sites More sharing options...
nickxc Posted May 17, 2004 Report Share Posted May 17, 2004 Ya I dont see whats wrong with it. Your gas tank is no different than a gas can. watch the pump and see how much gas you put in to fill it up then add the proper amount of oil and jump on it a couple times. Do a couple hard wheelies leaving the gas station and shees fine. done it a lot with no problems. Quote Link to comment Share on other sites More sharing options...
