Instaling A Winch In A Shee
The banshee itself can be used as a winch.
You already have a wench on your Shee, you just have to use it. Next time you are going out, wrap 25 - 50 feet of strong polly rope around your bumper. When you get stuck, find a tree out in front of you to tie onto. Run the rope through the bars of your lower left a-arm and under your left foot peg. Tie the bike end of the rope to one on the spokes on your rear sproket. Start your bike and put it in low gear and SLOWLY let out the clutch. Some care must be taken to ensure that you do not catch the rope in your chain. As the rope is wound around your axle you will pull yourself out of the mud. Running the rope through the front a-arm will keep the front end from digging in, or flipping over. Good Luck.
**Quoted Blacksmith Posted: Jan 28 2004, 06:42 PM URL**
Edited by DIRTBIKEZ
You can get one of those handheld lever-operated deals. They're pretty light, and fit in a 6-pack rack easily, or you can find other creative locations to hold them while you ride. They seem to work really well. You'd have to have a battery or pretty darn high output stator to run one, and there's more additional weight in the front.
