banshee_kid350 Posted May 5, 2004 Report Share Posted May 5, 2004 I just pulled off the clutch side case to look at the water impeller. And the housing that the impeller sits in looks kinda marked up but thats at the very bottom where the impeller doesnt touch but as you go up more on the left side of the housing it feels un even with the rest of it like it has been rubbing but the impeller looks fine. Does anyone know if this is this normal? And will I be okay to put it back together like it is? Quote Link to comment Share on other sites More sharing options...
dirtclod20 Posted May 5, 2004 Report Share Posted May 5, 2004 Since you have it apart, I would order a pro-design impellor and put it in. The stockers are absolute junk and I think they are better served as garbage. Better off to fix it now then be on a trail and it melt on you. Marc Quote Link to comment Share on other sites More sharing options...
sredish Posted May 5, 2004 Report Share Posted May 5, 2004 Since you have it apart, I would order a pro-design impellor and put it in. The stockers are absolute junk and I think they are better served as garbage. Better off to fix it now then be on a trail and it melt on you. Agreed, better than it melting, breaking or stripping, which all are common occurences with them. Quote Link to comment Share on other sites More sharing options...
