banshee76179 Posted May 4, 2004 Report Share Posted May 4, 2004 (edited) My buddies she won't start Banchetta said check the slide... Question is: how do I adjust the slides 1 is all the way down.. The other 1 is about half way down? Thanks, Edited May 4, 2004 by banshee76179 Quote Link to comment Share on other sites More sharing options...
ledofthezep Posted May 4, 2004 Report Share Posted May 4, 2004 A clymers will walk you through step by step... on each slide there's a little ball bearing....on the side of each carb there is a little window. You want the little bearing to show up in the window on each carb...then they're in sync. Quote Link to comment Share on other sites More sharing options...
banshee76179 Posted May 4, 2004 Author Report Share Posted May 4, 2004 Thanks Led! Quote Link to comment Share on other sites More sharing options...
gomer Posted May 4, 2004 Report Share Posted May 4, 2004 led could u be a little more specific on were the window is i cant find it lol i have tried or maybe someone can post a pic thanks Quote Link to comment Share on other sites More sharing options...
Banchetta Posted May 5, 2004 Report Share Posted May 5, 2004 If one slide is halfway up, then most likely your cable isn't all the way in the top of the carb or it got pulled out of the junction box where the cable goes from 2 to 1....Check your cable, thats where your problem will be, your adjustments won't be that far off.... Quote Link to comment Share on other sites More sharing options...
bansha60 Posted May 7, 2004 Report Share Posted May 7, 2004 On the right side of the quad, you will beable to see one of the windows, its right above the overflow vantricula, and on the neck Quote Link to comment Share on other sites More sharing options...
