yan Posted May 4, 2004 Report Share Posted May 4, 2004 (edited) i already post about tires and got ok responses but what size should i get i dont realy race and never been to a track i need good groung clearance and also want to go realy fast what is the size on the stock banshee tires so what size for good ground clearance and speed what should i get 6 ply razors or hole shots or ............. Edited May 4, 2004 by yan Quote Link to comment Share on other sites More sharing options...
boonman Posted May 4, 2004 Report Share Posted May 4, 2004 How much do you have to spend? If you can afford 6 plys, get 'em. 20-11-9 is about the best of any world size wise..... Quote Link to comment Share on other sites More sharing options...
bigboybanshee Posted May 4, 2004 Report Share Posted May 4, 2004 If I remember right you posted once saying you ride trails quite a bit. If that is the case I'd recommend a set of 22's. I had 20's on mine and my swingarm was bottoming out ALL the time. Just my .02 Quote Link to comment Share on other sites More sharing options...
KRMit Posted May 4, 2004 Report Share Posted May 4, 2004 Depends on the terrain. I love my 20" tires and will probably stick with that size. I agree with Bigboy if you go over a lot of rocks and such, but you may just be better off getting a good skidplate. After all, there's only 1" of clearance difference between 20" and 22" tires. Quote Link to comment Share on other sites More sharing options...
sredish Posted May 4, 2004 Report Share Posted May 4, 2004 Remember to keep your gearing in mind when choosing tire sizes. Quote Link to comment Share on other sites More sharing options...
boonman Posted May 5, 2004 Report Share Posted May 5, 2004 With enough speed, you can skip over anything.... I used to ride trails with 18" MX tamers....... Quote Link to comment Share on other sites More sharing options...
