chase73 Posted May 4, 2004 Report Share Posted May 4, 2004 Hey all need a favor can you tell me or look at your banshee and tell me where the oil breather line and the water pump breather line rout to there is a tee connector under the tank does another line just route of that and act as a drain ?????? thanks Quote Link to comment Share on other sites More sharing options...
boonman Posted May 4, 2004 Report Share Posted May 4, 2004 On my bike it goes up towards the steering stem... from the tee...... It is a vent. Not a drain..... Quote Link to comment Share on other sites More sharing options...
MotulMonsta Posted May 4, 2004 Report Share Posted May 4, 2004 The tranny vent lines will run up under your tank and down around the back of the radiator..the radiator lines will run under the tank, back to the res. then back under the tank and behind the rad. as well...shit load of ugly tubing running under there. I suggest getting rid of it. Quote Link to comment Share on other sites More sharing options...
chase73 Posted May 4, 2004 Author Report Share Posted May 4, 2004 Thanks Quote Link to comment Share on other sites More sharing options...
BansheeBrian Posted May 5, 2004 Report Share Posted May 5, 2004 Yeah,I'm not big on all that tubing that runs from the tranny.Is there a way to eliminate or move it? It's disturbing the view of a chrome-like Noss head. Quote Link to comment Share on other sites More sharing options...
BrokeStonedBiker Posted May 5, 2004 Report Share Posted May 5, 2004 i think it depends if you like to ride in water or not. if you dont then i thnk you should be able to shorten the quite a bit Quote Link to comment Share on other sites More sharing options...
