Clutch Boss Removal Help
Im trying to access the shift star to see why my trans only has 1st and 2nd gears. I cant seem to get the clutch boss off, i dont have any tools to hold it in place while trying to get the nut off. Any tricks or do I need a special tool. Thanks
I just took mine off today. Used an impact, w/ a regular socket and it came right off. No need to worry about holding it in place if your using an impact...
Edited by Otis
To see if it's bound up you should not have to pull anything off other than the clutch cover. :unsure: Move your shifter & you'll see where the shift fork grabs the star & you'll be able to see if it popped out and is outside of the star & bound up in 2 gears. If so, take a small flathead & unbind it. I'd recommend shimming up your shifter also after getting the gears unbound. ;)
