Mxracer776 Posted April 30, 2004 Report Posted April 30, 2004 for anyone who is looking to replace the stock cdi box on your shee i would recommand buying the dyna fs cdi box it is flat out awsome.it works great and is cheaper then stock.higher rev limitter and great power and with 4 preprogramed ign curves.if you purchase the sofeware kit you can program your own curves.i had to put in bigger mains to run it but thats all. easy to hook up, excellent craftsmanship and a warranty to boot. Quote
superchicken Posted May 11, 2004 Report Posted May 11, 2004 got one not to long ago had a problem with my coil,but after i got that stait im lovin my dyna.you deffinatly can feel a differance Quote
@@banshee_rider@@ Posted May 11, 2004 Report Posted May 11, 2004 thats right it has four curves you can get but the problem if you have a degree key the timing should be 0 or it want work good for non modified shee Quote
jinx44 Posted May 11, 2004 Report Posted May 11, 2004 Dyna's customer service is second to none. THey are very helpful and if you think your ignition has a problem, send it to them for free testing. Also, make sure you run resistor spark plugs. Quote
