Car Audio Guys, I Need Some Help
Otis
I have a yellow top and a red top under the hood of my truck.
I can crank the stereo with the truck not running for a good long time
and if I do kill that yellow top, my red top is fresh to
crank up the engine and then my 225amp wrangler alternator
charges them both back up through 4/0 cable. You need a battery
isolator, which is basically just a high current relay, to run the system off of
one battery when the engine is not running, yet charge and run off of 2
batterys when the engine is running :cheers:
banshee04le- Where did you pick up your high out put alt? Was it a direct bolt on/plug in, or did you have to do some mods to get 'er to work? If you have any pics of that set up(batteries and alt) could you email me a few r1otis@yahoo.com
I'm going to be doing a tune up, and plenum gasket([censored]ing Dodge engineering) replacement this weekend, so i figure as long as the old alternator has to come off, might as well replace it with a new(HO) one.
if anyone happens to be in the area this weekend, and wants to help out, i'd be more then happy to supply the beer/pizza!!!..... :D
Edited by Otis
High output alts will need you to modify your power running into them.. If you dont know what your doing i suggest taking it to a shop. However, how many watts are you running? I dont believe that was ever mentioned...
I have a 120 now...but was thinking of going to 136(i think thats what it was) out of a 3/4 ton truck.
I went to a dodge messege board and was told that for what i have (stereo, extra lights.....) that my alt should be fine...It's when you start going "overboard" ( 40 amps, 30 subs, off-road lights as big as big as the sun, and winches that'll pull a house from its foundation.... ) that you'll need to upgrade the alt.
Since i pulled the deck out and blew out the connections, i've had no problems...
I was talking about wattage on your amps pushing the subs..
ohhhhhh, my bad..... :jesterlaugh: ..i think it's a 125, but not real sure. It's an old MTX 750 something....
I thought about the Optimas, but am better off just stickin w/ the auto zone ones that i have...the way the desert heat kills a battery, they dont last long out here, and free replacement is still free replacement
as far as car audio is concerned, you dont need any extra batteries or alternator upgrades.. Nor do you need a cap. It would just be wasted money. However, if you have other things like lights or whatever else you have on your vehicle, you might need it for that.. But like I said, as far as car audio and the amp, your problem was simply a bad ground connection, no need for more power..
Yeah , which is fine by me(no money spent)....cause i have a lotta other things i need(see aslo WANT) to do to the truck and little money to do it w/....
:lol:
