erbilabuc Posted April 29, 2004 Report Share Posted April 29, 2004 what are the part #'s??? Quote Link to comment Share on other sites More sharing options...
McSkinner Posted April 29, 2004 Report Share Posted April 29, 2004 Don't know the part numbers but maybe this will help. I used this method and my kickstarter is way better than it ever was even brand new. Cheap too. Holyman tech. kickstarter no rattle Bye the way, Thanks Holyman. Quote Link to comment Share on other sites More sharing options...
erbilabuc Posted April 29, 2004 Author Report Share Posted April 29, 2004 dam i was searching for that but couldnt find it thanks Quote Link to comment Share on other sites More sharing options...
nasty01banshee Posted April 29, 2004 Report Share Posted April 29, 2004 (edited) Order Qty Ref. Part No. STARTER DESCRIPTION REQ Price Each 1 4L0-15660-01-00 KICK AXLE ASSY 1 $46.82 2 4L0-15641-00-00 GEAR, KICK (22T) 1 $27.88 3 90468-26091-00 CLIP 1 $2.40 4 90508-30051-00 SPRING, TORSION 1 $4.52 5 4L0-15666-00-00 SPACER 1 $6.31 6 248-15668-00-00 STOPPER 1 $2.60 7 93102-20484-00 OIL SEAL 1 $1.93 8 4L0-15651-00-00 GEAR, KICK IDLE (26T) 1 $41.02 9 164-17417-00-10 SHIM 1 (1.0T) 1 $2.20 10 90214-15020-00 WASHER, CLAW 1 $2.58 11 99009-15400-00 CIRCLIP 1 $0.75 12 2GU-15620-01-00 KICK CRANK ASSY 1 $79.39 13 93507-32031-00 ...BALL 1 $0.40 14 90501-12081-00 ...SPRING, COMPRESSION 1 $1.40 15 93210-14369-00 ...O-RING 1 $0.75 16 90151-06010-00 ...SCREW, COUNTERSUNK 1 $0.51 17 90336-42049-00 ...PLUG, TAPER 1 $1.20 18 97017-08030-00 BOLT 1 $0.98 cd-rom Edited April 29, 2004 by nasty01banshee Quote Link to comment Share on other sites More sharing options...
Banshee~ Posted April 29, 2004 Report Share Posted April 29, 2004 OrderQty Ref. Part No. STARTER DESCRIPTION REQ Price Each 1 4L0-15660-01-00 KICK AXLE ASSY 1 $46.82 2 4L0-15641-00-00 GEAR, KICK (22T) 1 $27.88 3 90468-26091-00 CLIP 1 $2.40 4 90508-30051-00 SPRING, TORSION 1 $4.52 5 4L0-15666-00-00 SPACER 1 $6.31 6 248-15668-00-00 STOPPER 1 $2.60 7 93102-20484-00 OIL SEAL 1 $1.93 8 4L0-15651-00-00 GEAR, KICK IDLE (26T) 1 $41.02 9 164-17417-00-10 SHIM 1 (1.0T) 1 $2.20 10 90214-15020-00 WASHER, CLAW 1 $2.58 11 99009-15400-00 CIRCLIP 1 $0.75 12 2GU-15620-01-00 KICK CRANK ASSY 1 $79.39 13 93507-32031-00 ...BALL 1 $0.40 14 90501-12081-00 ...SPRING, COMPRESSION 1 $1.40 15 93210-14369-00 ...O-RING 1 $0.75 16 90151-06010-00 ...SCREW, COUNTERSUNK 1 $0.51 17 90336-42049-00 ...PLUG, TAPER 1 $1.20 18 97017-08030-00 BOLT 1 $0.98 cd-rom Wow looks like you got a lot of time on your hands not that thats bad Quote Link to comment Share on other sites More sharing options...
nasty01banshee Posted April 30, 2004 Report Share Posted April 30, 2004 nahh, just a quick copy & paste off the repair CD, check out the link... Quote Link to comment Share on other sites More sharing options...
baldwinville Posted May 2, 2004 Report Share Posted May 2, 2004 Just take off the kick starter and then take it apart. clean it really good with brake cleaner. if the oring is brokes then find one the same size at your hardware store. i have had the same problem and never replaced it just cleaned it out. cheap easy and youll be riding in no time Quote Link to comment Share on other sites More sharing options...
