Kx60 Question.....or Any 2 Stroke
Took my kid to the track yesterday and his bike started bogging real bad. Figured it was just loaded up so i pulled the plug and kicked it a few times. Cleaned the plug and it ran fine for another 10 minutes or so. Bike idles fine and even runs about to 1/4 throttle but when you gun it it dies and starts back firing through the silencer. Figured i would take the carb apart and give it a good cleaning and do a pressure test. Crack seal was leaking on the flywheel side. I know air leaks are a big NO NO but do you think this had anything to do with the back firing and bogging? Cant get the damn float to stop sticking either.....I will have to figure out the float issue as well but one thing at a time.
check
