To The Tune Of $1500
I took my banshee to D and M racing in glendale a little over a month ago, because upon draing the oil there were some aluminum shavings present. They split the cases found a loose shift star and a broken c -clip. The clutch basket was badly worn as was the clutch. The inside of the cases look as if the bottom end had come apart once before as there was some gouging in them.
So they fixed the transmission, put a hinson basket with a barnett clutch in, bored it with wisecos, cut the head, lightened the flywheel, advanced the timing, welded and trued the crank, and new seals and bearings. I'm taking it to buttercup this wednesday. :)
  • 3 weeks later...
