Cyliner Threads Stripped
I was doing routine coolant maintenance on my 03 shee.
I drained the left side coolant after loosening the bolt & than the right side
and unhooked the water pump hose and let that drain.
But when it came time to tighten the coolant bolt back on the left side cylinder,
the threads inside the cylinder just melted away like butter when I went to torque it down to 7ft pounds of torque. Te engine was also cold when I performed this operation.
Can someone tell me how to do a Tap and then a Time-Sert Install.
Also is this a common problem on all ATV or just the Banshee :(
I was totally bummed out
