MotulMonsta Posted April 21, 2004 Report Share Posted April 21, 2004 Good tip. If your running after-market suspension and like me it has a remote res. and you mount it on the sub frame rail right above the chain tucked nicely under the fender with good acess to the dampening knob..Make shure you check that it doesn't interfere with the chain's travel range. After 4 years with my res. in the same position, I somehow managed to knock it in just a bit and my chain ate up the underside of the res. damn near causing it to rupture. Had I just taken 5 more min. to look things over, I could have avoided a now costly repair...as I'm going to buy a new rear shock and send that one out along with some busted up old frond shocks to be rebuilt. Least I'll have two complete sets of shocks now. Quote Link to comment Share on other sites More sharing options...
sheechandchong Posted April 22, 2004 Report Share Posted April 22, 2004 I mounted mine on the opposite side under the frame, never had a problem. sorry to hear about yours cause a aftermarket rear ain't cheap. Quote Link to comment Share on other sites More sharing options...
