Gas Heavily Sprying Out The Pipes
That is a possibility. My old Tecate 4 had a super leaky needle valve. Guess where all the gas would go? not out the plugged overflow! When you start it up, it'd spray premix in back for a few feet if I had forgotten to shut the fuel off.
Is this just when you are starting it up, or all the while when it is running?
Well is it oil or Gas spraying out the pipes? I don't see how splitting the case wrong would make gas spray out the pipes, but oil definately...
Gas would evaporate ALOT faster than oil, and coolant is usualy a different color...
You should find someone to do a leak down test...that would tell you what is going on.
Edited by Justintoxicated
