TORS......throttle over ride system......safety device that stops a sticking throttle and retards timing to stop overrevving when off the throttle. It'll often times fail causing poor spark or retarded timing leaving you to hours of problem solving..... I disconnect mine asap from past experience of them failing, not worth the trouble...The main brain is located just above the left exhaust. There is no performance gain either way....
