hey guys to start off im a fuckin idiot banghead , ok i was riding my g/fs shee and the idle screw fell out then it wound out real bad. i found the screw put it in and now shee won't start wat should the settings be on the carb for the air screw and idle screw, it has PTRs and fatboy silencers. i live in central alberta canada, it summer now bout +16 degrees celcius.
oh god plz help me :shootself::shootself:
Set it to the same as the other one.....If it doesn't start, then check the choke tube...or a stuck slide that is wide open, you can check that through the air box w/ a flashlight..
