bbluebanshee Posted April 18, 2004 Report Posted April 18, 2004 (edited) i am buying a set of 33mm pwks, taper bored to 35s. from what he says, the carbs were set up for alcohol. what size jets and needle should i use? here are the following mods: 5mm stroker longrod stage 3 port polish coolhead w/21 cc cut domes pro circuit pipes and silencers k&n pod filters i am running at sea level any help would be appreciated. i just need a good starting point thanks Edited April 18, 2004 by bbluebanshee Quote
Banchetta Posted April 19, 2004 Report Posted April 19, 2004 I'd say start w/ a 165 main, needle 2nd clip from the blunt end, cgl needle, 42-48 pilot.....This will be a close starting point. I'm running a 4mil stroker w/ 35mm carbs... Quote
bbluebanshee Posted April 19, 2004 Author Report Posted April 19, 2004 thanks for the info, i will give it a try!! Quote
