Fmf Vs Cheetah
jiffy
That is what i was thinking i ride dunes 95% of the times and drag race up hills.
I was just thinking for the money not much more to go aftermarket cyl this year stock stroke (have my crank welded or chance it holding a year)And then next year geting a stroker a 7 maybe everyone has a 4. I want reliablity and speed but the faster you go the less reliable it is. I was just thinking if i port it with the stock stroke and then go stroker i will have to report and run a plate i dont want to run a plate so go 4 mil and port this is where i run into the $ aspect of going to aftermarket cyl.
? do you have to run a plate on the aftermarket cyl if they are ported for a stock stroke and then you go stroker like the stock cyl. I am assuming you d
  • Replies 36
  • Created
  • Last Reply
Top Posters In This Topic
You will run into the same problems with aftermarket cylinders if they are set up,ported for a stock stroke.You would probably still be able to turn it into a 4mm stroker if the port job aint too wild to begin with but a 7mm most probably not.
Hey T-Rex is the way to go. Order the cylinders and pistons set up for your crank, stock, +4, +7, +10 or +12mm no spacers under them as they make them set up for your engine. I have a 72mm bore, +7mm stroke. For more info check out http://www.teamracersedge.com/ These are the people who cast and produce the T-Rex and they know thier shit.
:cheers:
Jim
All of them come already set up for the crank you want to run.
