My banshee will not start it is not getting the right amount of gas i think. But if I put a small amount into the cylnders then put the spark plugs on it starts. And runs great. I just put on pro curicuit pipes and 220 jets. I put a few holes in the air lid. What esle should i do guys. And new spark plugs. When the engine is warm she starts up great.
Two things. Pc pipes like a richer pilot, at least for mine it did...Try a 30 pilot, that'll make a big difference. Also, make sure you didn't switch the carb bowls...ONly one carb bowl is for the choke carb.....Next, check your compression. Low compression will make a bike start hard when cold....Better to catch it now, before parts go flying...
ALL stock shees have a 25 pilot in them...Pc pipes have terrible idle and low end w/ stock 25's, they need way more fuel then other pipes on the pilot circuit..
first off your way to lean you should be running 270 or280 mains, well this all depends on your elevation also id go up on your mains your not getting enough gas
hmm didn't know that always seen posts thought they had 27.5 in them till I actually looked at mine the other day :)
how do you tell the diff. ? like a dummy i did both carbs at the same time .
today i cleaned my carbs and put in some 300 mains in helped a lil but still ran like shit , BTW the plug wires are ok . i pulled the lid off the air box and hit seemed to rev better but i didnt get to ride it like that . im waiting for the 27.5 pilots shop didnt have any. it starts easy and idles good just when powering into it , it craps out .. sounds like chit too .... banghead
jeff
jeff
On some models, the choke carb bowl will have a brass tube only. The newer ones have brass tubes on both, but only one bowl has a little jet in the bottom of the bowl for the choke....Idles good and starts good, but falls off after.....Its one of two things...ONe, your tors is kicking in. Disconnect the little black box above the left exhaust, disconnect the parking brake switch, If problem still persist, then lower your needles one notch....Raise the clip towards the blunt end to lower the needles.....
ok got ya ill have to check the bowls . the tors have been disconnected. and same goes for the parking brake. so that rules tham out . ill mess with it this weekend
this thing is killin me banghead . thanks again banchetta uv been alot of help .
jeff
