Wheel Psi
I have 22x11x9 Maxxis Razr rears... And wondered what PSI I should put in them...
I have them at like 20 PSI maybe less, and they have the balloon affect. I would like them to flatten out more, but it seems when I take some air out they dont change shape, just hardness.
damn r they bouncing around man that's a lot...j/k
4-6 rear
7-10 front...
BET THAT THING FLOATS WITH THAT PSI
  • 3 weeks later...
Are these air pressures the same with all tires? I have hole shots on mine.
I have a cut in the side wall of my front tire, should I put a tube in it or just replace the tire? The tare did not put a big hole in the side but the guts of the tire are showing enough that it looses air. I pluged it with tire plugs for know just to move it around.
man your crazy....they prolly dont go flat cause you had so much air in them....but yeah 4-5 in the back...ive even ran 3 psi before and it was a bit low but works good
I run my realtors at 0psi in the snow.....just make sure that theirs a little bit of air still coming out when I push on the valvestem.
My holeshots I run at like 3-5 psi depending on conditions.
You guys all run a high pressure front tire. I run mine at like 4. Soft enough that it absorbs energy, forms to rocks, etc etc, but hard enough that if you hit something its not gonna push into the rim.
