bronco91shee Posted April 14, 2004 Report Share Posted April 14, 2004 if it is just the first seal, u just have to pull the sidecase off. if its past that, then idk. but i had the first one leak, and had it fixed in a jif. just pull the footpeg, shifter, and sidecase off. pull it out, and replace it. thats all. good luc and peace out Quote Link to comment Share on other sites More sharing options...
ledofthezep Posted April 14, 2004 Report Share Posted April 14, 2004 Look at this pic,...see those three bolts holding on my case saver? Behind there is a neutral overide switch assy cover. Yours is probably cracked...you can replace it without cracking the case, I'd recommend draining your oil 1st though and there's an o-ring you'll want to keep too for the new assembly. Look in the electrical section of a banshee microfiche & you can get the part number, I don't have it on hand. Not much to it. Quote Link to comment Share on other sites More sharing options...
bronco91shee Posted April 14, 2004 Author Report Share Posted April 14, 2004 srry dude i read wrong, i replaced the shift shaft. i have no idea about the sprocket. srry again peace out Quote Link to comment Share on other sites More sharing options...
cb67rs1 Posted April 14, 2004 Report Share Posted April 14, 2004 you can replace the shaft seal for the sprocket without pulling the motor and splitting the cases. Quote Link to comment Share on other sites More sharing options...
