duketj8 Posted April 14, 2004 Report Share Posted April 14, 2004 When I pulled my reeds out there was no reed cage. Is this a normal aftermarket reed set up? Does anyone know what type of reeds these might be? Quote Link to comment Share on other sites More sharing options...
99LRDblaster Posted April 14, 2004 Report Share Posted April 14, 2004 When I pulled my reeds out there was no reed cage. Is this a normal aftermarket reed set up? Does anyone know what type of reeds these might be? huh? no reed cage? what were the reeds attached to? Quote Link to comment Share on other sites More sharing options...
duketj8 Posted April 14, 2004 Author Report Share Posted April 14, 2004 OK so I guess it would have a reed cage but it doesnt have the metal part where the reeds are stopped. Quote Link to comment Share on other sites More sharing options...
vmaxup Posted April 14, 2004 Report Share Posted April 14, 2004 They are boyseen reeds . You dont need the stops Only stock ones need them Quote Link to comment Share on other sites More sharing options...
Ducman Posted April 14, 2004 Report Share Posted April 14, 2004 If there is a little mettle plate that the 2 screws go through at the base of the reed, then that takes the place of the reed stop plate that is attached on the stock reed cage. Boysen reeds use them and call it a rev plate. Quote Link to comment Share on other sites More sharing options...
