coolhead03 Posted April 12, 2004 Report Posted April 12, 2004 I seriously need to get a new clutch any info would be apreciated. Quote
frocashmoney24 Posted April 12, 2004 Report Posted April 12, 2004 ebc makes a great clutch, run it for a year and still strong , never slipped and i think its only like 60 bucks Quote
Banchetta Posted April 13, 2004 Report Posted April 13, 2004 I liked my Duncan clutch. It lasted 4 years, but was back ordered a couple of weeks ago and I got an EBC....So far I like it......Pulls semi easy and holds up to my stroker.... Quote
locogato11283 Posted April 13, 2004 Report Posted April 13, 2004 ebc makes a great clutch, run it for a year and still strong , never slipped and i think its only like 60 bucks word. Quote
bigboybanshee Posted April 13, 2004 Report Posted April 13, 2004 I ventured off and put a Vitos clutch in mine and love it so far!! It grabs really well and is not too terribly hard to pull. Got it for 80 bucks on fleabay. Quote
fixitrod Posted April 13, 2004 Report Posted April 13, 2004 I'm running a barnett dirt digger and it also holds up to the stroker. Quote
roosthrower Posted April 13, 2004 Report Posted April 13, 2004 tusk may not be the absolute best out there, but for 30 bucks it is hard to beat. The pull isn't to bad after you get used to it and it it is holding up well. No slippage at all. Quote
coolhead03 Posted April 14, 2004 Author Report Posted April 14, 2004 Thanks for the help guys..Does that ebc come with evrything you need for sixty bucks. Where did you get it? Thanks again Quote
MULLET~BOY Posted April 14, 2004 Report Posted April 14, 2004 i'm running a tusk clutch holdin up to my 370 lr on alky dragg ported and it was like 30 bucks my barnett on the other hand expolded into like 50 peices Quote
coolhead03 Posted April 14, 2004 Author Report Posted April 14, 2004 Wow a $30 clutch holds up to your alky. how long has it been in there? Quote
Proquad101 Posted April 14, 2004 Report Posted April 14, 2004 You say you have to much stuff done to your bike that your stock clutch won't hold up. I have only known of 2 motor that a stock clutch with the 3 fzr springs would not work for and they both were the trinity power-valve motors ( 95 hp+). So unless you have a trinity motor, a stock clutch with the fzr springs will work just as good if not better than all the other clutches out there. If you want proof look at my banshee I have been running a stock clutch and fzr springs with a passion stroker/longrod motor for along time. But hey thats just my opinion you do what you want. Quote
MULLET~BOY Posted April 14, 2004 Report Posted April 14, 2004 it lasted 4 tripps my transmison had some problems but when i pulled the clutch out it looked exactly the same as it did when i put it in and hell for 30 bucks i can aforrd to replace it twice a year if i have to and it still will cost less then the 80 dollar barnett that blew up in one trip stock clutches actully do work good from what i have found just need stiff springs you can buy just the springs from alba Quote
coolhead03 Posted April 14, 2004 Author Report Posted April 14, 2004 Yeah im still useing the stock springs so maybe i just need stiffer ones. It just tends to slip a little when ridin hard Quote
coolhead03 Posted April 14, 2004 Author Report Posted April 14, 2004 Also my flywheel is shaved. maybe that has somthing to do with it.Im gonna take it apart this weekend and see whats up with it. Quote
Proquad101 Posted April 15, 2004 Report Posted April 15, 2004 my fly wheel is also shaved. If you put the 3 springs in it I think you will be happy. Quote
